Discussion topic: Netflix
Message posted on 24 Jul 2023 07:50 PM
Netflix
Anybody having issues with Netflix through Sky Q? I've been told to refresh apps and unplugging box and from mains. Getting tedious... can anyone help?
Message posted on 24 Jul 2023 07:59 PM
Re: Netflix
Hi @Valldoreix
If you can get into your Netflix on Q try go to the Left hand Netflix menu.
Scroll down to the bottom and scroll right and select Get Help.
On the next screen there is an option to reload Netflix. Try this.
Message posted on 24 Jul 2023 09:27 PM
Re: Netflix
Thank you, but I can't actually get into Netflix... it just has the title and buffering wheel...
Message posted on 24 Jul 2023 09:29 PM
Re: Netflix
hi @Valldoreix
Try a Reset Settings in the Q box hidden menu. It may help.
