Discussion topic: Connection problems
Message posted on 24 Jul 2023 09:05 PM
Connection problems
Hi
my television won't connect to the Internet tried resetting
Message posted on 24 Jul 2023 09:12 PM
Re: Connection problems
@mooney62 wrote:
Hi
Hi @mooney62
Assume this is your main Q box.
Have you carried out a Network reset?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 24 Jul 2023 09:22 PM
Thanks but I have done all that and it still won't work
Message posted on 24 Jul 2023 09:23 PM
no still won't connect
