Discussion topic: Netflix pin lock
This message was authored by: An25
Netflix pin lock
Been watching Netflix which is part of out package, for years. All of a sudden now asking for a pin?
don't have one.
Re: Netflix pin lock
Hi @An25   There is a chance that your Netflix account has been hacked. If this is the case, then only Netflix can help you.
https://help.netflix.com/en/node/114277#:
When do you this pin.
Is it before you enter the Netflix app on your Sky Q?
If so go to controlling pin access on apps in this Sky help article;
https://www.sky.com/help/articles/managing-parental-settings
If it's within your Netflix account, you need to login to your account to reset or remove the account or profile pin, as described here;
https://help.netflix.com/en/node/24805?q=Pin
or
https://help.netflix.com/en/node/114277?q=Pin
