Discussion topic: My sky Q box keeps disconnecting from network whilst watching Apps forcing me to reset my router
Message posted on 03 Apr 2025 07:30 PM
My sky Q box keeps disconnecting from network whilst watching Apps forcing me to reset my router and my mini boxes are disconnecting also. I have upgraded to full fiber 900mbps and a broadband engineer has been back out and tells me it's a problem with my skyQ as everything else connected to WiFi is fine. Sky not interested in fixing the problem
Message posted on 03 Apr 2025 08:28 PM
Re: My sky Q box keeps disconnecting from network whilst watching Apps forcing me to reset my router
Looks like you need to carry out a Network reset on the main Q box @MJO1972 not just reset your router.
