This discussion topic has been answered Discussion topic: Netflix on second tv not loading
Message posted on 15 Jul 2024 01:11 PM
Please help, Netflix won't load for the past week on our second tv. We have re booted, unplugged, etc etc and still does not load. Works perfectly on main tv
Message posted on 15 Jul 2024 01:51 PM
Hi @Kat431
Did you also reboot your main Q box first as follows.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 15 Jul 2024 01:41 PM
Re: Netflix on second tv not loading
Are you seeing a red spinning circle?
Hi @Kat431
Message posted on 17 Jul 2024 08:12 AM
Yes....just turns forever
Message posted on 17 Jul 2024 10:24 AM
Doing this could well fix it:
You can let Sky know via this form - https://forms.office.com/e/VGr0tUpv67
Message posted on 17 Jul 2024 11:44 AM
Hi I have just done that and it hasn't changed the red circle 🔴 turning on second tv 😫
