5
This discussion topic has been answered Discussion topic: Netflix on second tv not loading
This message was authored by: Kat431
Please help, Netflix won't load for the past week on our second tv. We have re booted, unplugged, etc etc and still does not load. Works perfectly on main tv
Re: Netflix on second tv not loading
Hi @Kat431
Did you also reboot your main Q box first as follows.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
@Kat431
Are you seeing a red spinning circle?
Hi @Kat431
Avatar for Kat431
Yes....just turns forever
@Kat431
Doing this could well fix it:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4691069/highlight/true#...
You can let Sky know via this form - https://forms.office.com/e/VGr0tUpv67
Avatar for Kat431
Hi I have just done that and it hasn't changed the red circle 🔴 turning on second tv 😫
Answered - Go to Answer
