3
This discussion topic has been answered Discussion topic: Netflix not working
This message was authored by: Melanie+harte
Netflix not working
Netflix not working. Hasn't been working properly for weeks
Avatar for Melanie+harte
This message was authored by: Melanie+harte Answer
Re: Netflix not working
Hi spoke to sky and they told me to do a software update. It appears to have worked. Thankyou
This message was authored by: ThePope27
Hi @Melanie+harte
Have you tried refreshing the apps ?
To refresh the apps in the Hidden menu, follow these steps:
1. Press the Home button and navigate down to Settings without selecting it.
2. While Settings is highlighted, press 0 0 1 Select.
3. Choose Apps.
4. Highlight "Refresh all Apps on this box."
5. You'll see a message confirming that your apps are being refreshed, which will remain on screen until you press Dismiss to return to normal viewing.
6. It's recommended to wait at least 5 minutes before doing so.
7. Note that the refresh process can take up to 24 hours to complete.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
This message was authored by: Adrian21
Hi
New here and hope someone from Sky reads this.  I have the Netflix not working issue.  I tried every 'fix' I could find on this forum and nothing has worked permanently.  I might have it work for a day or two then nothing again.
For me the Sky Netflix app is not fit for purpose.
My solution was to re-configure how my whole home cinema system works resulting in the smart tv now being the 'hub' rather than Sky Q.  The Samsung Netflix app works fine everytime and is actually much quicker.
If you have the equipment available my advice is to not bother with the Sky Netflix app.  They really should get this sorted out.
