Discussion topic: Netflix and Disney
This message was authored by: Rachel152
Netflix and Disney
They have both disappeared from the app section
Re: Netflix and Disney
Hi @Rachel152
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
