Discussion topic: Connectivity problems with our sky a boxes
This message was authored by: swan18
Sky a box won't hold router settings we need an engineer please
Re: Connectivity problems with our sky a boxes
Hi @swan18
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
