9
This discussion topic has been answered Discussion topic: Netflix HDR
This message was authored by: Oompaloompa
Netflix HDR
A bit of a wierd one this, but I thought I would see if anybody has any idea how ro solve this problem.
I have full Sky Q package with Netflix Premium add on. Never had any problems, all worked fine. A month ago I renewed my contract without making changes aside from chamging ISP at the same time, now enjoying fibre with beFibre - connection is solid at 500Mbps. I have noticed that Netflix now does not display content in HDR (it is labelled as such in the programme precis though). Wierdly, it is the same issue via the tv native app and via the SkyQ box. I do know that when I last checked, HDR was available and being played on films/series where now it is not.
I have checked all the settings I can think of, they all seem fine but then they should be as I have not changed any hardware or cabelling or anything for that matter. HDR is instantly available on Prime/YouTube/iPlayer on the native apps and where possible, via the apps on Q.
I'm completely baffled by this and would welcome any suggestions.
TIA.
This message was authored by: nigea99 Answer
Re: Netflix HDR
@Oompaloompa wrote:
A brief moment of hope there, it was something I hadn't considered but alas, the correct subscription is displayed.
in which case I am sorry but I have no further ideas
That said and Really clutching at straws even though your speed check works is to reboot your router (although I am guessing you already tried it)
Re: Netflix HDR
TIA.
hi @Oompaloompa
Have you double checked your current subscriptions/bills to make sure that you still have the Boost To Premium add on
Avatar for Oompaloompa
Level 4 icon
Re: Netflix HDR
Hi @nigea99 - yes, the correct subscription shows on my account - "Boost to Premium."
Re: Netflix HDR
hmmm
Something I have just spotted in settings is an HDR setting on/off
In the SKY App  - Get Help - Video
Worth checking that this is set to on & presumably on your TV's app
Although no idea why that would change
I would also run the Check Your Network check just in case for reason it is not recognising your current max speed.
Level 4 icon
Re: Netflix HDR
Thanks for your time @nigea99 - yes, I have tried and checked all of them. I am thoroughly confused😤
Re: Netflix HDR
Likewise
Can you log in on a desktop & check your account details there (you might be able to see the details in other apps) and check that it also indicates Premium
Level 4 icon
Re: Netflix HDR
Re: Netflix HDR
Level 4 icon
Re: Netflix HDR
Bingo - should have thought of that earlier but that's the beauty of this community, the obvious is just that sometimes even when you don't realise yourself.
Thanks for your help @nigea99
Re: Netflix HDR
So glad it worked
