Discussion topic: Some of the tv channels do not have a satellite signal
This message was authored by: JE22
Need to know how to get satellite signal for all channels
Re: Some of the tv channels do not have a satellite signal
If it's your own dish then it's probably out of alignment.
You'll either need to call Sky or pay a local engineer to check.
@JE22
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s still likely to be a significant delay in getting an appointment so it may be quicker to contact a local satellite company but that would be at your own expense.
