Discussion topic: Need ew sky q bix
This message was authored by: Mandm2
Need ew sky q bix
I need a new sky q box Iwhen I insert card it is coming back out I have to use tape to try and keep it in place
Re: Need ew sky q bix
hi @Mandm2
I have escalated your post to a SKY support team, who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
Escalation Info
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
