Discussion topic: Need engineer out regarding my TV
Message posted on 11 Dec 2023 01:26 PM
I need engineer out as no satalite signal followed all the steps channels still not working
Message posted on 11 Dec 2023 01:35 PM
Re: Need engineer out regarding my TV
I've moved your post to the Sky Q board - assuming you have Sky Q
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
