Discussion topic: Need a sky engineer
This message was authored by: LAS22
Need a sky engineer
One of my sky boxes have not been working for months. Need a Sky engineer
Re: Need a sky engineer
@LAS22
Main box or mini box? In what way isn't it working? Have you not reported this to Sky already in the last few months?
Avatar for LAS22
Mini box. I did months ago and it was concluded that I needed a new remote control. I got a new remote control but it still doesn't work so I gave up.
@Daniel0210 wrote:
@LAS22
@LAS22
Did Sky lead you through a reboot, ie… reboot the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for LAS22
Yes I did that then. We can try again. I have been with Sky for nearly 8 years and it would be great if someone could just physically come to my home and help me get it up and running
They'll probably want to do a Mini box swap by  post or courier first.
Avatar for LAS22
Okay that's fine with me.
@LAS22
Give Sky another call to arrange that. They'll probably want to do more troubleshooting first which you may have already tried.
