Discussion topic: Need a longer power cable
This message was authored by: deewee
My mini box is attached to the back of tv and works but the cable is not long enough to reach socket without an extension can I purchase a longer cable is it something specific?
Re: Need a longer power cable
Hi @deewee
It's a standard IEC C7 (figure of eight) cable.
Readily available at longer lengths from most electrical retailers or online.
hi @deewee
you can get them from a variety of sources in various lengths.
They are standard C7 fiigure of 8 leads
This message was authored by: Ericdogs
No the connection going into the power supply isround. With little pin holes
Then that's not a Q Mini box, it's a v2 main box.
@Ericdogs
The other side of the external PSU can be extended as described above because the transformer takes an IEC C7 plug.
@TimmyBGood wrote:
@deewee
You can still extend the other side of the external PSU as described above because the transformer takes an IEC C7 plug.
Hi @TimmyBGood
It's @Ericdogs  that has the power supply box
