Discussion topic: Need a longer power cable
Message posted on 23 Oct 2023 08:06 PM
Message posted on 23 Oct 2023 08:10 PM - last edited: 23 Oct 2023 08:11 PM
Re: Need a longer power cable
@deewee wrote:
My mini box is attached to the back of tv and works but the cable is not long enough to reach socket without an extension can I purchase a longer cable is it something specific?
Hi @deewee
It's a standard IEC C7 (figure of eight) cable.
Readily available at longer lengths from most electrical retailers or online.
Message posted on 23 Oct 2023 08:11 PM
hi @deewee
you can get them from a variety of sources in various lengths.
They are standard C7 fiigure of 8 leads
Message posted on 24 Oct 2023 12:31 PM
No the connection going into the power supply isround. With little pin holes
Message posted on 24 Oct 2023 12:33 PM
Then that's not a Q Mini box, it's a v2 main box.
Message posted on 24 Oct 2023 12:38 PM - last edited: 24 Oct 2023 01:22 PM
The other side of the external PSU can be extended as described above because the transformer takes an IEC C7 plug.
Message posted on 24 Oct 2023 12:48 PM
@TimmyBGood wrote:
You can still extend the other side of the external PSU as described above because the transformer takes an IEC C7 plug.
Hi @TimmyBGood
It's @Ericdogs that has the power supply box
