Discussion topic: NEW SKY Q BOX NOT WORKING
This message was authored by: melw
I had sky q with a mini box installed Thursday. Just lost programmes on the main box (just Home screen showing but not the small screen view on the page. The mini box is working fine. If I switch of the main box the mini box will lose programmes, I guess.
I am worried that when I switch on the main box, the mini box may not work which would be a disaster for our handicapped son. His there a way to reset avoiding interruption to the minibox.
Re: NEW SKY Q BOX NOT WORKING
Hi @melw
With the main Q box on
Try completly resetting it's Bluetooth remote.
Avatar for melw
The remote is working OK ie letting me access and view all settings.  The box seems as though its not receiving TV signals but the mini box is behaving normally with all functions working so it must be sending WiFi to the minibus.
Thanks for answering.
