Discussion topic: NETWORK CINNECTION STATUS RESET MESSAGE
This message was authored by: DaleA1980
Message posted on 21 Jan 2024 01:52 PM
The home page user interface has been replaced with a long message instructing to "Go to settings and check your network connection status to reset." Everything is connected and working perfectly except the home page interface which has been replaced with this message.
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Jan 2024 02:13 PM
Re: NETWORK CINNECTION STATUS RESET MESSAGE
@DaleA1980 Have you tried rebooting your main Q box ie
Message posted on 21 Jan 2024 02:29 PM
Laing1 thank you for your message. I managed to sort the issue out. I needed to connect the SkyQ box separately to the TV connection. Got a little confused but it's all good now. Thanks again.
