4
This discussion topic has been answered Discussion topic: N
This message was authored by: Lou196
N
I can't record on my device and it won't connect to internet
Re: N
@Lou196 wrote:
Thank u for your reply, yes we have tried that and it still doesn't work
Hi @Lou196
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Re: N
@Lou196 Have you tried rebooting your main Q box ie
then
rebooting any mini boxes you may have
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Lou196
Re: N
Re: N
Hi @Lou196
Avatar for Lou196
Re: N
Amazing, thank u, that worked
