My volume wont work new TV brought today and still won't work
Solved! Go to Solution.
Have you reporgrammed your remote control to your new TV?
Does your new TV use IR for its remote control? Some TVs use bluetooth that the Sky remote does not use
You need to pair your remote with your new TV. See Sky's help here: https://www.sky.com/help/program-your-remote
My volume wont work was working now just stopped
Sky Q? Sky+? Sky Glass/Stream?
Sky Q and remote is paired
