Discussion topic: My viewing card is not working
This message was authored by: Tracy73
A few weeks ago my card was saying that it wasn't inserted correctly but it was. I followed the steps and finally got it working. It has done the same again tonight but this time even restarting is not working
Re: My viewing card is not working
Hi @Tracy73
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
@Tracy73
You could try a refresh of your card.
Go to:
Home>Settings>System info.
Highlight the viewing card number and then select 'Setup'
Then select 'Use this option to trigger a callback'
There is no call involved. It's refreshed using the internet.
Avatar for Tracy73
Thank you so much I will give those ideas a try.
