Discussion topic: My upstairs tv will not link to sky box. It keeps dropping out. Internet signal good and main tv goo
This message was authored by: Lilian+Weatherley
The upstairs tv keeps dropping out and says it's not linked to sky q box or there is no signal. Downstairs tv working fine and internet signal fine. Seems to be a problem with upstairs Sky q box
Avatar for Lilian+Weatherley
Level 0 icon
Not helpful
Have already explained
Re: My upstairs tv will not link to sky box. It keeps dropping out. Internet signal good and main tv
@Lilian+Weatherley
What have you tried already? You say a no signal message… do you mean no satellite signal?
Hi @Lilian+Weatherley
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
This message was authored by: MegDicky12
I changed the Bt broadly router and now the Skybox upstairs won't connect
did you change the new BT router to match the SSID and password of the old one?
if not I assume you did a Network reset on the Q box. Did you do the same on the mini?
