Discussion topic: My tv still doesn’t work despite resetting the router, po wrong off for at least 39 seconds and
Message posted on 16 May 2025 02:31 PM
My TV is still not working
I have switched off, rebooted the router, left for 39 seconds and still nothing 16/06/25
Message posted on 16 May 2025 02:33 PM
Re: My tv still doesn’t work despite resetting the router, po wrong off for at least 39 seconds and
Is it stuck on standby? Does it show no network connection? Does the Sky Q box have a green light but your TV is a blank screen?
Message posted on 16 May 2025 02:34 PM
Hi @Kkk1 have you unplugged the Q box for 30 seconds ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 16 May 2025 02:35 PM
@Kkk1
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
