Discussion topic: My tv screen is saying atmospherics
This message was authored by: Rob19811
I have no tv signal and it's saying atmospherics
Re: My tv screen is saying atmospherics
@Rob19811
I've not seen that error message before. If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Doesn't sound like a Sky error message?
@Rob19811
Are you perhaps a subscriber to Sky Network Television Limited in New Zealand?
https://help.sky.co.nz/s/article/t100-no-signal-atmospheric-conditions-warning
This forum is for Sky UK, part of Sky Group (a division of the Comcast Corporation) : Sky (NZ) would be different hemisphere, different continent, different country, different satellite and consequently different reception hardware which generates error messages we don't see here.
https://en.m.wikipedia.org/wiki/Sky_(New_Zealand)
https://en.m.wikipedia.org/wiki/Sky_Group
@Rob19811
Unless you're actually using a box with that firmware in the UK/ROI, I guess, but I'm pretty sure that's not possible...
