Discussion topic: My tv and remote are not working, we have changed the battery but it still doesn’t work.
This message was authored by: Waheed1
My tv and remote aren't working. We have changed that batteries for the remote and it still is not working. There is a 'Check Device Power' message in the screen, however, we have checked multiple times and everything is connected. This issue have been ongoing for 2 weeks.
Re: My tv and remote are not working, we have changed the battery but it still doesn’t work.
Hi @Waheed1
If the led on the front right of the Q box is still Amber try the following.
Try pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
