Discussion topic: My multi box is on but the channel guide is showing no listings?
This message was authored by: Np647966C
My multi box is switched on but the channel guide is showing no listings
Re: My multi box is on but the channel guide is showing no listings?
@Np647966C  Your other thread you created in the accessibility forum has been removed as you rasised the issue here.
@Np647966C Have you tried rebooting your main Q box ie
then
reboot your mini box
