Discussion topic: My sky stopped working Saturday and only thing I get on is someone saying I will be back
This message was authored by: Stephenbeesley
My sky isn't working only thing I get on is someone saying I will be back
Re: My sky stopped working Saturday and only thing I get on is someone saying I will be back
@Stephenbeesley  Your post isn't making any sense.  Who will be back?  Who have you spoken to?  Have you logged the issue with Sky?
@Stephenbeesley
In what way isn't it working? Any visible on-screen error message?
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Avatar for Stephenbeesley
Level 0 icon
It's an advert that is playing Constantly showing different programs and than a lady says I will be back
Hi @Stephenbeesley
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home.
Have you tried rebooting your Q box?
If you could switch your Q box on by pressing the Stand by button on the box then
try completly resetting your Bluetooth remote.
Failing all this if you get any error messages post vacillating with details and the forum will try to help.
