Discussion topic: My sky q mini boxes keep dropping connections
Message posted on 26 Feb 2024 07:56 PM
My sky mini boxes (2 of them) keep losing connection with the main box
Message posted on 26 Feb 2024 08:14 PM
Re: My sky q mini boxes keep dropping connections
Hi @Cliff+Rose
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
