Discussion topic: My sky q mini box has stopped working
This message was authored by: Tracy+Blanche
My q mini box has stopped working following the electricity going off
Re: My sky q mini box has stopped working
@Tracy+Blanche whats happening with your mini box are you seeing any messages on screen ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Tracy+Blanche
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
