Discussion topic: My sky q box multi room won’t turn on after filling the prompts from blank screen
Message posted on 11 Aug 2024 12:35 PM
My sky Q (multi room) box won't turn on after the prompt. When the screen goes blank press the home button. But nothing happens
Message posted on 11 Aug 2024 12:52 PM
Re: My sky q box multi room won’t turn on after filling the prompts from blank screen
@Scott147 have you tried pressing the on button on the front off the box in cse there is a problem with the remote.
The on button is the one that shows the amber light
if that works
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
