Discussion topic: Does the Q 1 TB box output 4K ?
Message posted on 11 Aug 2024 11:35 AM
Hi
I have just got a 4k TV, finallly. But I am having problems getting 4 K from my Sky box. Does the Sky Q 1TB box output 4K ?
Message posted on 11 Aug 2024 11:38 AM
Re: Does the Q 1 TB box output 4K ?
@NJones wrote:
Hi
The original 1TB was not UHD but the later 1TB are
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
https://www.sky.com/help/articles/check-which-sky-q-box
Message posted on 11 Aug 2024 12:44 PM
Thank you.
Looks like I need a new box.
Message posted on 11 Aug 2024 12:49 PM
Message posted on 11 Aug 2024 12:53 PM
@NJones wrote:Looks like I need a new box.
You may be asked to make an administrative payment to 'upgrade' your box too. (All boxes are lent for the duration of your subscription)
You may be able to negotiate on the basis of adding the UHD sub...
