20 Aug 2024 11:40 AM
The tv shows no signal, but sky q light is still green. I have to unplug it and do the start up routine
20 Aug 2024 11:53 AM
Hi @Tigger11
20 Aug 2024 12:11 PM
@oldfella @Thank you have done this, hopefully it will stop doing it now!!
