Discussion topic: My sky q box keeps freezing or losing sound. Fast forward or rewind skips and lags
This message was authored by: SharonF2
My sky q box keeps freezing or losing sound. Fast forward or rewind skips and lags Before coming back on. It's happening multiple times a day
Re: My sky q box keeps freezing or losing sound. Fast forward or rewind skips and lags
Hi @SharonF2
