Discussion topic: My sky q box is not connecting to internet
This message was authored by: MoBer
My sky q box is not connecting to internet - have already tried the online fix
Re: My sky q box is not connecting to internet
Hi @MoBer
Have no idea what you have tried when you say online fix.
Have you carried out a Network reset exactly as follows on your main Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
This message was authored by: Wayne51
My sky q box is also not connnecting today to the internet. I have tried rebooting, router, q box and mini. nothing working!!!!!
This message was authored by: Gerry+K
I've had no problem for 2 years. Until last night.
My Sky box is not connecting to my internet (Sky broadband).  It says no network connection.
I've held down WPS (more than 10 times) and pressed up to 3 minutes.
It says it's still searching
