Discussion topic: My sky not working
This message was authored by: Car29
My sky not working
My sky box is not connecting to my tv
Avatar for Car29
Re: My sky not working
My brand new skybox is suddenly not talking to my tv. I can see it is recording programmes and the on/off lights work. Also the remote is new and works but not to the tv
You've posted in the Sky+ forum, but there are no new Sky+ boxes. Do you have Sky Q, perhaps?
Avatar for Car29
You're probably right I have a Q box but not a glass tv, when it was fitted I was told it was mark 2 but that is irrelevant as it was installed by a sky engineer so it must be installed correctly as it has been working ok until it suddenly isn't
@Car29
I've moved your thread to the Sky Q board. Are you seeing any error message on screen?
Avatar for Car29
I have screen to look at as it's blank. But my free view is working ok as are all other tv functions the fault is the skybox
Hi @Car29    It sounds like your TV is not on the correct HDMI input. Try cycling through the HDMI inputs with the Sky Q remote (if it is paired) or your TV remote.
Avatar for Car29
It is the correct HDMI as I have it for years with no problems and when sky engineer changed boxes  recently it was correctly fitted and working. Then for no reason it wasn't surely can only be skybox as everything else is ok
Hi @Car29 Try placing both your TV and SKYQ box on standby, then on your SKY remote press the SKY logo button on the top of the remote, this should start your SKYQ box and then your TV with hopefully a picture?
hi @Car29
When the SKY Q box is on try pressing the following keys in sequence on the SKY Q remote
Home 1 0 8 0 Home
Avatar for Car29
Woke up this morning and the skybox is suddenly working, thanks everyone for your help
