Discussion topic: My sky multi room isn’t working
Message posted on 01 Oct 2023 12:04 PM
Sky main box is working but not multi room
Message posted on 01 Oct 2023 12:10 PM
Re: My sky multi room isn’t working
Hi @ShaneONeill
Reboot the mini as above.
