2
This discussion topic has been answered Discussion topic: My sky mini box won't play any channels , the schedule is there but blank preview , I have reset bo
This message was authored by: 19sunshine71
My sky mini box won't play any channels , the schedule is there but blank preview , I have reset box and reconnected to internet and main box
Re: My sky mini box won't play any channels , the schedule is there but blank preview , I have rese
Hi @19sunshine71
Reboot the mini as above.
Hi @19sunshine71
Avatar for 19sunshine71
Level 0 icon
Sorted thank you for your help
