Discussion topic: Cut Coax Cable Repair ?
Message posted on 18 Jul 2024 07:40 PM
Place holder for a post to be moved
Message posted on 18 Jul 2024 06:25 PM
Re: Do i need an aerial cable to go in the back of my sky q box?
If my doaxial cable is cut can it be repaired without being replaced?
Message posted on 18 Jul 2024 07:46 PM - last edited: 18 Jul 2024 07:48 PM
hi @zain4567
Do you mean the Cable from dish to SKY Q ?
SKY won't do such a repair but an independent satellite installer might - although it is possible to be done by anyone suitable.
Is the cut inside the house or outside ?
Technically it can be done - you need two F plugs & and F-F connector
F Connectors
If the cut is outside then this needs to be done so it is fully weatherproofed which can be achieved with 'self amalgamating tape; tightly wrapped around the cables & joning connectors.
