Discussion topic: My sky isn't working
Message posted on 21 Jun 2024 09:54 AM
My sky isn't working, I have no signal and saying it is unknown
Message posted on 21 Jun 2024 10:25 AM
Re: My sky isn't working
@Sky2527
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
