Discussion topic: My sky is not working
This message was authored by: Max_40
My sky is not working, it just shows a black screen.. I have tried turning it on and off but hasn't worked.
This message was authored by: Jones_The_Cat
Re: My sky is not working
Is the Q box receiving power? Are there lights on the front? What colour are they? Have you tried turning the box off at the wall for a minute then powering it back on to reboot it? Is your TV on the correct HDMI input?
Avatar for Max_40
Hi , there's just one green light on I have turned it on and off but it hasn't worked.
This message was authored by: Jan531
Hi, I am having the same problem, black screen on TV, green lights on as it should be, tried rebooting it but no joy. Engineer came out yesterday and changed the box and the HDMI lead which seemed to fix the problem but today the same thing has happened. Spoke to Sky again and they ran through the usual rebooting etc, they are now sending me another box as they think there is an issue with the one they put in yesterday.
@Max_40 with the box switch  on and showing a green light then press the following on the remote
the home button followed by 1080 then the home button again
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Also - Are you 100% sure the TV is on the right HDMI input?
