Discussion topic: My sky f1 channel problem
This message was authored by: Cesario
Hi there my sky f1 channel is freezing
Please can someone help me to stop the freezing please? Thanks
Re: My sky f1 channel problem
hi @Cesario
Possibly try a power down restart of your main SKY Q box :
 Use the remote to place it into standby mode
 Then remove the power to it (either switch off at mains or remove the power plug)
 Wait at least 30s
 Then re-apply the power & wait for it to fully restart - this may take a few minutes.
If that doesn't help then possibly a lsight problem with your dish alignment - although not ideal try looking further down the channel list for a different resolution - I have UHD on 406  so HD is on 857 & SD on 864
