Discussion topic: My sky control isn't working
This message was authored by: Nezie13
My sky control isn't working. When I press the power to switch it on,it comes on then goes back off. I have changed the  batteries. The blue light flashes and then it will come on then go back off again.
Re: My sky control isn't working
Hi @Nezie13
First try rebooting your Q box.
Then if necessary
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: Jannah2
Re: My sky q isn't working
My sky isn't working
@Jannah2
Your Sky Q box, or Sky Q remote which is the thread subject?
