Discussion topic: My sky box won’t connect to my broadband and I’ve followed the instructions repeatedly from settings
This message was authored by: Linz42
Repeatedly restarted and followed instructions but it won't work
Re: My sky box won’t connect to my broadband and I’ve followed the instructions repeatedly from sett
Hi @Linz42
Make sure that complete the following.
