Discussion topic: My sky box mini is not working
This message was authored by: Danny60
I can't access my sky box mini as it just freezes with a page  that says accessibility on Sky Q
Re: My sky box mini is not working
@Danny60 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
