Discussion topic: My system intermittently fails to record
This message was authored by: rb1940
I set the system to record and either there is nothing or it tells me the recording has failed. At other times, it works normally.
I regularly delete unwanted or viewed recordings to ensure there is space.
Re: My system intermittently fails to record
@rb1940 Have you tried rebooting your main Q box ie
