Discussion topic: My sky box keeps falling off wifi
Message posted on 03 Jan 2025 10:55 AM
I am a 23 year Sky customer. All of a sudden my Sky box does not stay connected to the internet. Go through the pain of rebooting, then fails again. Can't watch anything on apps. I have virgin broadband. Is it likely a Sky or Virgin issue?
Message posted on 03 Jan 2025 12:21 PM
Re: My sky box keeps falling off wifi
Hi @Jason66
Try completly resetting your connection.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 31 Jan 2025 09:02 PM
I am having similar issues except it's a Trooli fibre. Everything else stays in it fine, TV multiple phones (at least 😎 Alexa's IPads laptops. It is just the sky Q box. It is almost every day. It seems it doesn't like the non sky WiFi.
