Discussion topic: Sky sports
Message posted on 31 Jan 2025 08:18 PM
Sky sports
We subscribe to sky sports but we have no satellite
Message posted on 31 Jan 2025 08:26 PM - last edited: 31 Jan 2025 08:27 PM
Re: Sky sports
Do you mean you're seeing a 'no satellite signal' on screen message? SkyQ or Sky+?
Message posted on 31 Jan 2025 08:39 PM
Re: Sky sports
Hi, I have skyQ. Everything is working except sky sports. It says no satellite
Message posted on 31 Jan 2025 08:41 PM
Re: Sky sports
I have moved your post to the correct board.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
Message posted on 31 Jan 2025 08:42 PM
Re: Sky sports
Thanks I will try this in the morning.
