Discussion topic: My sky box isn’t working
This message was authored by: Fatimaali91
My sky box isn't working at the moment the screen is blank not working the screen is completely gone and not starting at all for 2 days I'm 68 years old and can I have engerneir to come to my house to come and fix it .
Re: My sky box isn’t working
Hi @Fatimaali91
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
