Discussion topic: My sky a remote isnt working
Message posted on 12 Jun 2026 05:16 PM
I've changed the batteries I've also unplugged my sky box for 30 mins and plugged it back in I then discovered it's not the box but my remote that's not working
Message posted on 12 Jun 2026 05:24 PM
Re: My sky a remote isnt working
@Janis53-
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket.
While your waiting, if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
