08 Feb 2024 06:11 PM
My sky Q mini box has no signal from this morning.
08 Feb 2024 06:19 PM
Hi @alarni
If your TV Message is No signal then this is an issue with the HDMI connection between the mini and TV.
Check that the TV set is set to the correct HDMI input for the Q box and also make sure that the HDMI cable is correctly located at both ends.
If your mini just no connection then try the following.
Reboot the mini as above.
